How to Rip DVD for iPhone 4S with DVDFab DVD Ripper?
05/27/2020
The iPhone 4S, released in 2011, is the fifth generation of the iPhone. Though iPhone 7 has been released, iPhone 4S doesn't withdraw cellphone market completely. You can see iPhone 4S is still on sale on some shopping websites. If you want to watch a DVD movie on your iPhone 4S, you need to convert DVD to iPhone 4S. DVDFab DVD Ripper can convert DVD to iPhone 4S at a high speed and make the output video perfectly suitable for your iPhone 4S on Windows or macOS. Now let's have a look at the conversion process.
Step 1: Choose the module
Run DVDFab 10 and choose the Ripper module.
Step 2: Load the source
Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
Step 3: Choose the profile
Navigate to the profile library on the top left corner of the main interface and choose Device >Apple >iPhone 4S.
Step 4: Customize the output video
Now you can choose the titles, chapters, audio tracks and subtitles, define the names of the titles by clicking corresponding tabs according to your needs.
Step 5: Select a directory and start the ripping process
Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
You see, it’s very simple to rip DVD to iPhone 4s with DVDFab DVD Ripper.
This tip only shows you how to rip DVD to iPhone 4s, but if you want to know how to convert video in other formats to iPhone/iPhone 4s, you can use DVDFab Video Converter to do the job.
